| Position |
Ident |
Spare part name |
Quantity |
Price [] per pc |
Type of price |
Validity |
| 0015 |
136480 |
HYDROSTAT HOSE PS-03 L480 |
1 |
| 0086 |
547104 |
CLAMP PS |
13 |
| 0105 |
234420 |
WIRING HARNESS Q PS-05 BV |
1 |
| 0106 |
587542 |
ELECTROMOTOR 220-240V MCA 61 CA |
1 |
| 0114 |
226510 |
DISCHARGING PUMP - SYNCHRONOUS PS HANYU |
1 |
| 0117 |
234844 |
TUBULAR HEATER IRCA |
1 |
| 0209 |
132222 |
CABLE WITH PLUG H05VV-F3G1.0 1550 |
1 |
| 0278 |
387524 |
CLAMP - WIRE D 10 |
1 |
| 0373 |
160966 |
DOOR SWITCH WITH BLOCKADE PS-05 ZV 446 |
1 |
| 0387 |
608557 |
ELECTRIC VALVE - DOUBLE 220/240EKI |
1 |
| 0519 |
667400 |
RUBBER SEAL |
1 |
| 0523 |
667401 |
CLIP FOR INITIATION SLEEVE |
1 |
| 0616 |
581213 |
TEMPERATURE SENSOR .NTC EPCOS |
1 |
| 0656 |
192570 |
INLET FILTER 0,3MH ISKRA |
1 |
| 0672 |
194555 |
HEATER CLAMP PS-03 CA |
1 |
| 0681 |
182715 |
WIRING HARNESS - PUMP PS-05 Q |
1 |
| 0682 |
182710 |
WIRING HARNESS - POWER PS-05 Q |
1 |
| 0683 |
182713 |
WIRING HARNESS - ELECTRIC MOTOR PS-05 Q |
1 |
| 0685 |
234497 |
WIRING HARNESS HYDROSTAT Q PS-05 |
1 |
| 0686 |
587703 |
WIRING HARNESS HEATER-EL.MOTOR GROUNDING |
1 |
| 0687 |
182717 |
WIRING HARNESS - NTC SENSOR PS-05 Q |
1 |
| 0688 |
182716 |
WIRING HARNESS - EL. VALVE COLD PS-05 Q |
1 |
| 0689 |
182712 |
WIRING HARNESS - DOOR SWITCH PS-05 Q |
1 |
| 0690 |
234499 |
HYDROSTAT |
1 |
| 0695 |
587311 |
SCREW PT80X50 EJOT A2K |
2 |
| 1028 |
192583 |
RUDDER-CONTROL UNIT PS-05 Q/1 AKO-12-GZ-6 |
1 |
| 0613 |
581268 |
BUTTONJOINT
1 040 |
1 |
